Vaccum diagram
Old Nov 14, 2004 | 06:59 PM
resqbubba's Avatar
Car: 1989 Firebird T-Top
Vaccum diagram
I am working on a 305 TBI to 350 TPI Swap. I was wondering if anyone has an accurate vaccum diagram for the engine, and if the MAP sensor is needed for the motor. If so, where does the MAP sensor vaccum line hook up to?? Thanks guys!!!
Old Nov 14, 2004 | 07:36 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
if youre using a '730 ecm, you need the map sensor. it is mounted on the back of the plenum, passenger side. there are also 2 vacuum ports below there, one for the map, the other for the fpr
InfernalVortex
Apr 20, 2021 11:31 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
rjcme
Sep 5, 2015 01:23 PM
