Tight iS GoOD!
Old Jun 1, 2001 | 09:52 PM
Remnant's Avatar
Tight iS GoOD!
OK, I took the whole steering wheel apart and tightned down the nuts to get the play out of the steering wheel. The steering wheel is tight... however, there is still play in the column. What else needs attention? I want it TiGHT!!!
90 IROC, LT1, 5 speed, convertable
Thanks...
Old Jun 1, 2001 | 10:49 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Did you check the bearings??
Is the play up and down or left to right?
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited June 01, 2001).]
Old Jun 1, 2001 | 11:08 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Did u check the big heavy main supports? when mine went, i had about 5" up and down
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
"I'd rather run last in a full out race, than to not have run at all"
Old Jun 1, 2001 | 11:23 PM
Remnant's Avatar
Well, The play in my steering wheel is L to R. The column does not move. It's solid. But it takes a little bit of a turn in the wheel before there is any TURN in the tires. When in the turn it's tight. ???????????
Amillionoh7
May 24, 2020 08:01 AM
evilstuie
Jan 9, 2020 08:29 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
red90IROCls1
Aug 25, 2015 06:56 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
