Who has the fastest 305 car?
Old May 29, 2001 | 05:37 AM
IROC KID's Avatar
I have a 305 tpi,the worse version because its the 86er with the junk cam in it,what the hell was GM thinking?,anyways i am wondering since alot of people on the boards seem to think 305s are junk,who is the fastest 305 owner that will shut up alot of 350s?,what is your horsepower and quarter times?
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
[This message has been edited by IROC KID (edited May 29, 2001).]
Old May 29, 2001 | 07:44 AM
86 IROCZ28's Avatar
I think all 305's Autos got the peanut cam not only the 86. Th e85 is the only exception but all the other years 86-89 all 305's auto's are rated at 190hp.
Old May 29, 2001 | 08:14 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I probably don't have the fastests 305 out there but I've done very well at the track with it. Well enough that there have been quite a few people not believe me when I tell them its a 305. I've managed to get my LG4 with the stock bottom end down to a 13.4 at 101mph with no power adders. I really think I could get another .2 out of it with good track conditions. Willie has the fastest 305 that I know of but he has a supercharger, I think he is in the low 12's?
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old May 29, 2001 | 08:26 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
On this board, I think Willie has one of the fastest. He is either now breaking into (or about to) get into the 11s. I think ODB has times in the high 10s if IIRC; but I cannot recall if that was with his 305 or 383.
Old May 29, 2001 | 10:21 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
preston smith ran 9s with his old vortech blown 305 TPI (w/ stock intake too.) He switched to a single turbo set up that should annhilate the vortech times...
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old May 29, 2001 | 11:25 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Jeez, the fastest I ever went was a 13.99 at 102 mph. That was the only time I ever broke into the 13's with that car (by a hair!) Then the motor started going south...the tires wore out, the posi didn't lock, etc...
Old May 29, 2001 | 11:34 AM
IROC KID's Avatar
I am glad to hear that these 305s can be made fast,i read about one doing 13s in gm high tech and it was supercharged,i am still stunned that someone got into the 9s,so i guess on the board Willie is the fastest so far,i hope he sees this topic so he can tell us his times,jbenge,your times of 13.4 are definately respectable,that means your car can run along stock lt1 camaros all day, very nice.
Old May 29, 2001 | 12:22 PM
Yarnboy's Avatar
Stunned?? Man..I just read about a CRX that does 8.50's. There are plenty of mid 9 second DSM' with a 2.0 motor..a 5.0 with a big blower or a huge turbo can easily hit 9's.
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
Old May 29, 2001 | 12:39 PM
IROC KID's Avatar
I am not stunned at a ***** doing that,the car might have half the motor but it also has half the weight too,i just think that people underate the 305 motors ALOT,i was just suprised to see that someone on the board got it into the 9s,most cars i read or hear about are 12s and 13s.
Old May 29, 2001 | 01:10 PM
IROC5.7TPI's Avatar
<font face="Verdana, Arial" size="2">Originally posted by dhirocz:
Jeez, the fastest I ever went was a 13.99 at 102 mph. That was the only time I ever broke into the 13's with that car (by a hair!) Then the motor started going south...the tires wore out, the posi didn't lock, etc...</font>
My buddies 89 5.0 5M G92 car did the same thing. As soon as he hit 14.0 the car started breaking. We took the oilpan down to change the seals and found 2 piston skirts laying in it. He put it back together anyways and is still driving it 2 years later.
He threw a ring gear tooth from the 9-bolt using Drag Radials and launching at 4000.
The car was all stock internally.
See ya's.
Mike L.
"If it feels good - stay in it "
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, airfoil, Random Tech Hi-Flow Converter (soon to go byebye!). ALL STOCK otherwise.
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old May 29, 2001 | 07:09 PM
mtx28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IROC KID:
i hope he sees this topic so he can tell us his times...
</font>
i dont wanna speak too soon, but i think with his new ATI, D1SC S/C he hit 12.2 on his first run..and is hoping to break into 11's with some tuning. It's quite a beast('87 305 auto)
  • 83 Z28-- not a pretty site to look at, 200k miles and im sure it was treated like a rental car every day of its sad life(before i got it).. sold, thank the lord
  • 74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Old May 29, 2001 | 08:42 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
It looks like you guys are having fun on this thread and thought I would join in. I've had numerous combinations of power adders, etc. on my car so I'll try to be brief with each one.
Naturally Aspirated
14.07 @ ? (Can't remember the mph)
While many others are signficantly faster than I am, I attribute my slowness to the fact that my engine was built with a supercharger in mind.
Paxton (6 psig boost)
12.57 @ 108 mph (plus or minus)
90-hp nitrous
12.58 @ 109 mph
Paxton (6 psig boost) plus 50-hp nitrous
12.04 @ 114 mph
ATI D1SC (5 psig boost)*
12.26 @ 113.55 mph
*She's barely turning. Wait til I "pump it up"!!!
BTW, my car is Arizona emissions compliant and I drive it EVERY day, including for business.
Willie
Old May 29, 2001 | 10:53 PM
SUPER-SPORT-CHEVY's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 86 IROCZ28:
I think all 305's Autos got the peanut cam not only the 86. Th e85 is the only exception but all the other years 86-89 all 305's auto's are rated at 190hp.</font>
Diddo! all the cams were about the same the difference in hp was made with the less dished pistons HO modles and FI also gave the hp rating a little boost.
now lets see 82 lg4 very low output with 200c. stock run "in hight altitude 3900ft+" 16.9 at 88mph
with comp 250H cam and no cat or emissions equiptment non cc qjetcarb/distributor 15.3 92mph. not too bad considering there BB's runing 12's/14's NA of course.
Old May 29, 2001 | 11:03 PM
IROC KID's Avatar
Damn willie,your definately an inspiration to us 305 guys,thats crazy that your still emissions legal too. i think that i might give my 305 a chance at life instead of being thrown away for a 12 pack,lol,i had a 350 in mind for her this winter but perhaps i can build my 305 into an animal and when i am asked if its a 350 i will reply,nope just a 305,lol,i think that would be cool.how much are we talking willie to get a 305 tpi to where yours is?,keep in mind that mine is an 86 if that matters,where should i start?, i need some of ******* 305 build up 101.
Old May 29, 2001 | 11:19 PM
Willie's Avatar
Damn willie,your definately an inspiration to us 305 guys</font>
My plan was to stick with a 305 even though it would have been more cost effective to go with a 350. But I had a point to prove. I'm so glad I stuck with it. So far, my track kills include a 1998 LS1 Z28 convertible, a 1998 Corvette and a 2000 Camaro SS. I have yet to lose to any generation Mustang. All with my technologically outdated, displacement challenged IROC-Z. Can you say "SWEET"???
<font face="Verdana, Arial" size="2">thats crazy that your still emissions legal too.</font>
And Arizona's standards are equivalent to California's.
<font face="Verdana, Arial" size="2">...perhaps i can build my 305 into an animal and when i am asked if its a 350 i will reply,nope just a 305,lol,i think that would be cool.</font>
I couldn't have said it better myself. The only "problem" is that the other boys at the track tend not to believe me when I tell them my engine is a 305. (In all reality, it is bored over 0.020, so it's actually almost a 308.)
<font face="Verdana, Arial" size="2">how much are we talking willie to get a 305 tpi to where yours is?</font>
I never kept track of the $$$ I spent in the last three years. Suffice it to say I've spent many times over what I paid for the car. It's called a labor of love (or speed, if you will).
<font face="Verdana, Arial" size="2">,keep in mind that mine is an 86 if that matters,where should i start?</font>
It doesn't matter. The only difference is that yours came with a hydraulic cam and mine was a hydraulic roller. You can always change yours to roller.
Go to http://willie.camaro-firebird.org and click on "Mods and E/T's". It shows you the progression of my mods and resulting track times. It's not current, but you'll get the idea.
<font face="Verdana, Arial" size="2">, i need some of ******* 305 build up 101.</font>
I'd be glad to send you my list of mods. It's rather long, but very concise. Just e-mail me.
Willie
[This message has been edited by Willie (edited May 29, 2001).]
Old May 29, 2001 | 11:31 PM
IROC KID's Avatar
I am e-mailing you asap,i just really think having a 305 whooping a$$ is cool,most people dont care but i think having the OE block is something to take pride in.I was going to go with a TTA or GN motor as i think that would be cool as they should have made a turbo iroc,they made the iroc alot of show and no go compared to some cars like the GN that were sleepers.
Old May 31, 2001 | 06:15 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
I've run in the high 12's naturally aspirated & low 12's with 90 hp nitrous with my TPI 305 powered '92 Z28....
1/4 Mile Data:
No Nitrous:
6-99; 10:20 pm; Southern International Raceway, Tucson, AZ
13.251 sec @ 105.34 mph @ 3078 ft, 80 degrees F, 40 % rel. humidity
12.757sec @ 109.50 mph; altitude corrected
(13.251 sec * 0.9627 = 12.757 sec; 105.34 mph * 1.0395 = 109.50 mph)
90 hp Nitrous:
10-99; 10:00 pm; Speed World Motorplex, Phoenix, AZ
12.294 sec @ 113.145 mph @ 1250 ft
12.131 sec @ 114.684 mph; altitude corrected
(12.294 sec * 0.98675 = 12.131 sec; 113.145 mph * 1.0136 = 114.684 mph)
Calculated Peak Horse Power @ Wheels:
peak horse power = gross weight * (quarter mile speed / 234)^3
No nitrous:
3400 lbs * (105.34 mph / 234)3 = 310.18 hp @ rear wheels
3400 lbs * (109.50 mph / 234)3 = 348.40 hp @ rear wheels (altitude corrected)
90 hp Nitrous:
3400 lbs * (113.145 mph / 234)3 = 384.36 hp @ rear wheels
3400 lbs * (114.684 mph / 234)3 = 400.26 hp @ rear wheels (altitude corrected)
Calculated Peak Horse Power @ Crank Shaft:
horse power @ crank shaft = horse power @ wheels / (1 - % drive train loss)
drive train loss = approximately 15%
=> hp @ crank = hp @ wheels / 0.85
No nitrous:
310 hp / 0.85 = 365 hp @ crank shaft
348 hp / 0.85 = 409 hp @ crank shaft (altitude corrected)
90 hp Nitrous:
384 hp / 0.85 = 452 hp @ crank shaft
400 hp / 0.85 = 471 hp @ crank shaft (altitude corrected)
Rear Wheel Dynamometer Results (Bud’s Service Station, Phoenix, AZ, 10-99):
Measurement Conditions:
Measured @ rear (street) tires with no nitrous; atmospheric conditions: 94 degrees F, 43% rel. humidity, 1300 ft elevation
Rear wheel dynamometer torque measurements in 4th gear: (hp = tq * rpm / 5252)
Fuel pressure = 53 psig, base ignition advance = 6 degrees:
400 lb-ft @ 3100 rpm (236 hp)
410 lb-ft @ 3600 rpm (281 hp)
390 lb-ft @ 4200 rpm (312 hp)
340 lb-ft @ 4700 rpm (304 hp)
310 lb-ft @ 5000 rpm (295 hp)
Willie & Phil & I are going out to SIR, in Tucson, on June 29th to try out our "new mods" - we've also come to the conclusion that we will never be finished modifying our rides.........anyone else want to join us????
Tim
Old May 31, 2001 | 06:58 PM
Killer-Z's Avatar
Your car was a 305 5-speed? What did u do to get it there? How much did the free mods help? What were u lanching at and what were ur shift points? Derrick
Old May 31, 2001 | 06:59 PM
Killer-Z's Avatar
Sorry that wasn't supposed to be posted
Old Jun 1, 2001 | 12:21 AM
Car: Death Mobile
Engine: 666 c.i.
Oh yes. I forgot all about Tim Burgess....how could I ever do that? Forgive me Tim.
Old Jun 1, 2001 | 04:36 AM
IROC KID's Avatar
Thats awesome thta your car is in the 12s,sweet,it makes me really want to build my 305,i think it would be funny to smoke a 4th gen ls1 and say i only have a 305,lol, that would be cool,i plan to build my car this winter as long as funds are right,i have my choices to a 305,350,and the 3.8 with a turbo,i know the 350 is the cheapest route i believe,but saying you have a 305 or a 6 in it would be funny.
305 tpi,700r-4 with shift kit,16 by 9 American Racing cross laced wheels,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
Old Jun 1, 2001 | 07:55 AM
Willie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Killer-Z:
Your car was a 305 5-speed? What did u do to get it there? How much did the free mods help? What were u lanching at and what were ur shift points? Derrick</font>
Derrick,
Tim is the original owner of his '92 Z28. It is a 305, 5-speed car. If you'd like a list of his mods, e-mail him. He launches at 5,500 rpm and shifts around 6,000 - 6,200. Hope this helps.
Tim and I are good friends and work at the same company. It's kind of ironic that the two fastest (debatable) 305's are here in Tucson and that we did not know each other three years ago.
Willie
[This message has been edited by Willie (edited June 01, 2001).]
Old Jun 1, 2001 | 01:59 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Never got to a 1/4 mile dragstrip, but I had :-( a good 12 secong combo and spent around $1,000. My car is an 1986 Iroc. Stock it went a blazing 10.6 in the 1/8. Then came N20. It went to a 9.2(after tuning) in the 1/8. After I got tired of being slow I put in a compucam hydryalic cam 440/454'' and some Edelbrock coated headers(used for $200.00) and the car went 8.02 @ 88mph in the 1/88 which is deep in the 12's. and 9.0 @78 without the N20. Oh yea the only other things I did were 22-2400 stall when the tranny wennt out and no cat. I suggest this combo to everyone. Any questsions just ask.
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
[This message has been edited by NufNuffZ28 (edited June 01, 2001).]
Old Jun 1, 2001 | 05:46 PM
Killer-Z's Avatar
Thanks for the info willie. Love the car...even if it didn't do low 12's high 11's-thats just icing on the cake. I'll def. consult him for help. thanks again Derrick
Old Jun 1, 2001 | 05:47 PM
Killer-Z's Avatar
Iroc kid-Definitely go for either the 6 or the 305.
Old Jun 2, 2001 | 04:19 PM
IROC KID's Avatar
I am definately considering it,i just really want to make sure its the best choice,i really think the v-6 turbos have alot of potential,i will have my mind up this winter when i have the funds.
jhawkeye
May 25, 2022 06:33 PM
kyleb24
Aug 15, 2015 08:24 AM
drathaar907
Aug 10, 2015 07:44 AM
