just bought an 82, Z-28
Old Jun 2, 2001 | 04:05 PM
Dans91's Avatar
Car: 91 RS
just bought an 82 Z-28 and it needs a carb. for it to run, but when it had a carb on it I remeber when i started it it had shot flames out of the carb. I just wanted to know if anyone knew the cause of it?? It has a holly carb and a wieand intake manifold on it. It also has been sitting for quite a while now, maybe it is bad gas or something to that matter?? any help would be great. THANX!!!
Old Jun 2, 2001 | 09:11 PM
Vader's Avatar
Dan,
If the car has been unused for a while it's possible that the carburetor has dried out, the seals are no longer sealing, the float is sticking or the inlet needle/seat isn't sealing, and the fuel bowl empties into the intake as soon as the fuel pump starts moving fuel.
Get some fresh fuel to the carb. Get the engine running, and tap lightly on the carb air horn with a wood hammer handle. Sometimes a stuck float can be unstuck in this manner.
You can replace the carb or repair it. Repair is cheaper and you'll know exactly what you have when you're finished.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 2, 2001 | 09:13 PM
82camaro's Avatar
Car: 82 camaro SC
Most everything on a holley is fixable, I would repair it.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
GTAman
Jul 3, 2024 07:29 PM
New2Chevy
Sep 28, 2015 12:35 AM
masonta
Sep 1, 2015 06:40 PM
pimprs
Aug 24, 2015 11:20 PM
