Funny whistling/squeaking
Old Nov 19, 2004 | 11:14 AM
Brian Murray's Avatar
Car: '91 Pontiac Firebird
Engine: 4-bolt 350 TBI w/ Holley ProJection
Axle/Gears: 3.08, 10bolt
I started her up this morning, let it warm up for about 5 minutes and then let-er-rip down my street since I was late for school. Well, when its accelerating quickly, or even just free-revving quickly it squeaks! I think it might be my injectors, or this exhaust leak thats been getting progressively worse...
When I got to school I had about 2 minutes to have a look at what was making the noise, so with the motor on in neutral i revved it and it sounded liek the noise was coming from the exhaust, but it was pretty loud on the left side of the motor so I couldnt really tell where it was coming from.
Should I run some injector cleaner through it? I'm already replacing the exhaust with a Pacesetter catback.
TIA.
Old Nov 19, 2004 | 11:31 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Check you powersteering fluid level. Injectors aren't going to sqeal. Exhaust isn't really going to sqeal, it will click and tap like the injectors. Check your belts also.
Old Nov 19, 2004 | 04:33 PM
Just did PS. My belts were squeaking awhile back but it went away...
I was thinking it might be exhaust due to the fact that I have a HUGE leak and I was thinking that the hole might be shaped so that it whistles? Whatever the case is, it went away when i drove home, its most likely the belts.
thanks.
Old Nov 19, 2004 | 09:11 PM
305Camaro84's Avatar
Car: 1894 Camaro Berlinetta 305 auto
Engine: 305 LG4
Transmission: TH 700 R4
squeak
could it be your alternator, cause that will squeall but its more like a whine
Old Nov 19, 2004 | 10:03 PM
Re: squeak
just replaced that too...
And it only did it while cold... and only while the engine was loaded and accelerating. I'ts probably the belts thanks for the input all.
Old Nov 22, 2004 | 05:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Betcha its your belt(s). Its a common problem. If its V-belts, just replace them, they are dirt cheap. If its a serpy belt, try some belt dressing after you check the tentioner.
ex-x-fire
Jan 12, 2024 01:58 PM
Fronzizzle
Mar 18, 2019 08:29 PM
SlowCamaro88SC
Nov 5, 2001 04:26 PM
lazyano
Mar 30, 2001 11:29 PM
