Odd idle problem
Old Jun 3, 2001 | 03:45 PM
82camaro's Avatar
Car: 82 camaro SC
Odd idle problem
This is on my 1991 GMC Jimmy 4d 2wd 4.3L tbi.
I start it up and it idles too high and it continues to idle high after the engine is warmed up(15 minutes). Here is the odd part: If I move the shifter down just a little bit(still in park, but closer to reverse) the idle goes down to normal gradually(it takes about 3 seconds or so). Then the idle remains normal until even if it's put back up to the top of park or any other gear. It does this everytime I start it up. Idle compensates with the AC on, so I'm guessing the IAC is working correctly. I set the minimum air, reset the computer a bunch of times. The computer has no codes and all the sensors test out good. Anybody have any ideas? Even a guess? thanks,
Nate
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jun 3, 2001 | 04:52 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Try posting this in TBI to. U may get more responses to it.
Wish I could help.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
