"Knocking" on heaven's door?
Old Jun 2, 2001 | 05:43 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I think i've done it this time.On the highway the other day,some guy blew by me doing about 100 in a fairly new chev halfton.Normally that doesn't bother me ,but this guy was especially insolent.Long story short,i dusted him ,but he wasn't easy.Had to work the old girl pretty hard.When i let off her i could hear a slight knocking at around 2000 rpms.Oil pressure was still good,temp was good.It kind of sounded like a rocker was loose or something which made sense because i just did the whole top end this winter.Today i reset the valve lash ,did find the #8 cylinder valves were kind of loose,so i thought that i might have gotten lucky.Went for a road test and the noise is still there.What do you guys think?Rod bearing?Crank bearing would drop oil pressure right?The noise seems worse when i let off the gas if that helps.Does gm sell short blocks? ha!
86'Camaro Berlinetta SC,former 2.8,now 327 cid with 350 tpi heads(pocket ported)summit k1102 cam,305 H.O. aluminum intake,edelbrock 1405 carb,recurved HEI with accel adjustable vac advance can,rebuilt 700r with shift kit,B&M mega shifter,grant steering wheel,t-tops,american racing wheels,louvers....now if i had fresh paint,subframe conn.,cowl induction hood..sigh..
Old Jun 2, 2001 | 11:15 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
does it still sound like you've got a loose lifter?
we just went throught this with my buddies 81 malibu wagon(don't laugh it's a 10 second wagon)we adjusted the valves three times before we figured out that wasn't it!we pulled off the tunnel ram to check out the lifters
the #6 exhaust lifter was stuck.it wasn't traveling the full leagnth of the lifter bore.we had to force the lifter out with a pair of channle locks
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 2, 2001 | 11:32 PM
SUPER-SPORT-CHEVY's Avatar
Momma take these guns from me, cough, cough,
Well it does sound like it could be a rod bearing but if the oil pressure doesent drop than most likely its valve train related. If you adjutsted the rokers and its still there is could be a bad lifter. One of the lifters could have gotten fryed and could be bleeding to much oil causing a rocker to get loose.
Just a thought.
SSC
Old Jun 3, 2001 | 09:09 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
This is kind of encouraging.I didn't suspect the lifters because they were new,but i guess i could have gotten a bad one.I didn't spend a fortune on them,they were bought at V.I.P autoparts for around 30 or 40 bucks.The brand name was "wolverine" and they were the type that look like there's a paperclip at the top.I run 350 TPI heads and i think the valve springs are stiffer,so maybe the higher lift cam (420,442)plus the stiff springs ,might have killed it.Do you guys think thats why the #8 rocker was so loose?(lifter not pumping up?)This engine has never made a sound until now and i am really not hard on it,despite the half ton story.Could the high revs have finished the lifter off?If it was bottom end,would i see a oil pressure drop for sure?I still get 50-60 psi when cold.I want to thank you guys for the help and i invite anyone else to jump in with suggestions.A bad lifter sounds a lot better than rod bearing failure.
Old Jun 3, 2001 | 06:05 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Have to face it ,this is more than a lifter.This thing is shot guys.Took it out on the street and it's much worse than before.It's now a loud rapping noise,can't go into 2'nd without major noise.It's hard to say goodbye.Guess i'll start saving for a good wrench crate motor.
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
masonta
Sep 1, 2015 06:40 PM
