350 Cast #'s inside.
Here are the numbers I got off this block. I'm hoping it's a 350. I got the numbers from the passenger side front behind the alternator. They are - F0414 B or R then A
Please help. Thanks.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I think you need to look at the back of the engine, on the ledge on the driver's side. Then go to www.mortec.com and search for it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
On the back of the block, near the hole for the distributor, you will find like a 7 or 8 digit number. That is the casting number.
On the front of the engine, where the passenger side head bolts on, you will find a pad. On that pad should be some numbers stamped in it. Get those two things and I should be able to help you out.
