Top Dead Center, Lining up Distributor
Old Jun 3, 2001 | 06:52 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Ok here I go again....... I need help on timing the New Motor. I would like to say its just me so Putting my finger to the Plug hole is out. How else do I find top dead center intake to get this thing running right....... I NEED HELP!!!! I had an earlier post of watching the #6 Cyl and #1 intake valve but cannot find the info.
THANKS
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
Old Jun 3, 2001 | 07:01 PM
mrgto's Avatar
Usually what I do is take the drivers side valve cover off. I rotate the crank around to 0, watch the valves. As they go up and down as you rotate the crank, you will see when you are 180* off and when you are at TDC.
Old Jun 3, 2001 | 07:10 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
what i do when i'm by myself is line up the groove on the balancer with 0 on the timing indicator put the distributor in strait with the rotor pointed to number one hook up the wires fire it up if you get a shotgun blast your firing on number 8 maanually line up the marks again take the cap off see where its pointing if it is on number one pull the distributor out turn the engine over again and line up the marks to 0 now your set on number 1 if you take the cap off and its pointing to number 8(depending how many times it cranked over)take out the distributor and align the rotor with number 1 and fire it up either way it wont hurt and you dont have to take off the pita valve covers
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60'
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
sonu1975
Aug 11, 2015 08:38 AM
