Nitrous or a Cam that is the Question?
Old Jun 3, 2001 | 06:25 PM
Ernie's Avatar
I have enough money to get a cam (or)an
Edelbrock preformer RPM NOS system,
What should i get? How crapy is the stock
cam on L98at's. Will nos make my motor
run hotter when I use it.please help..
86 T/A L98 with T-5(orig an LG4)
Hooker headers
Performer RPM intake
holley 750cfm carb
cast iron 76cc heads with
2.02-1.60 valves
B&M ripper
Richmond 4.10's
Old Jun 3, 2001 | 07:07 PM
Enkil's Avatar
Cam. Definately a cam.
They make cams that are better than stock, and work even better with nos, so maybe you should check into those.
This is just personal opinion, but I'm not too fond of nos.. Sure it's cheap, and gives you rather impressive power gains, but it's hell on the motor.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 3, 2001 | 07:14 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you will melt those cast pistons like butter if it isn't dialed in absolutely correct what do you have done to the car?consider other things to make it quicker there is really no reason to upgrade a cam if the intake is stock look at gears a converter if it's auto afpr or decent chip on a stock motor those mods will help you more than a camshaft will
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60'
Old Jun 3, 2001 | 07:18 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
duh i guess i should of looked at your sig first go with the cam the lt4 is a nice piece very cheap also it was a pain in the *** before i figured out how to dial it in correctly or zz9 is supposed to be decent as well
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
