Rear Axle Identification Help
Old Nov 22, 2004 | 03:23 PM
tbroadfoot's Avatar
Car: 1996 Dodge Dakota
Engine: 3.9 Magnum
Transmission: 5 speed manual
I have a rear end with the following code stamped upon it. 5PH C194 2. I understand that the C194 is saginaw with a build date of 194 shift 2. However, I can not find any reference to the 5PH.
Supposely this rear axle is a positraction but the gear ratio is unknown. The rear end supposely cam out of an 1983 Trans Am Motor Sport edition but I cant find any reference to this axle code. It has disc brakes if thats any help
Any help would be great.
Old Nov 22, 2004 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take off the cover and look.
Whatever you see in there, that's what it is.
The "codes" only tell you what the factory put there; not what's there now.
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
