Smoke
Old Jun 3, 2001 | 09:14 PM
MurphsIroc's Avatar
Smoke
Hey guys, I didnt pass inspection cause of smoke comming out of my tailpipes, Failed cause of Visible smoke, they didnt even do an emmisions test, How can I get rid of this smoke? I want to get inspection done quick so I can start puttin on all my exaust and headers. Thanks, What do yo uthkn the problem is? is dark smoke not blue. Thanks
Old Jun 3, 2001 | 09:29 PM
Vader's Avatar
Dark smoke (soot) is generally due to an excessively rich mixture. Since you failed to mention what model/year/engine/fuel system you have in the test lane, I can't begin to tell you where to start looking for answers.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 3, 2001 | 10:00 PM
MurphsIroc's Avatar
Hey man, I have an 88 IrocZ Camaro 305TBI it has about 100k on the engine. hope this helps
Old Jun 3, 2001 | 11:30 PM
RARE-ROC-Z's Avatar
hey put in a 02 sensor, and then unplug your battery for about 30 minutes then replug it and then drive it around for about 20-25 mins slowly cruising, and then check that will change your mixture count in the comp. and then if that doesnt work, try cleaing some of your stuff
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
Old Jun 4, 2001 | 12:24 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
I have a 86 IROC-Z 305 TPI. I get blue smoke sometimes when I first start it. What could that be?
86' IROC-Z
5.0L TPI
Spohn panhard bar and LCA's
Old Jun 4, 2001 | 12:34 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by MurphsIroc:
Hey man, I have an 88 IrocZ Camaro 305TBI it has about 100k on the engine. hope this helps</font>
I'm not sure, but I don't think the IROC/Z was available with a TBI system. You might have a TPI, but in either case you should check the air filter, fuel pressure, oxygen sensor (should be replaced every 30,000 miles), PCV system, TPS setting, base timing setting, and AIR system operation.
One of those should get you closer to a solution.
Later,
Vader
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
