2 tenths in the quarter from TB bypass.
Old Jun 3, 2001 | 10:25 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I went back to the track today after the TB bypass run a 14.6 @93 mph. I love free HP.
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, BFG Drag radials, and 170* Stat.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
w/ drag radails 14.72 @ 92.1
“Fallen But Not Forgotten”
Old Jun 4, 2001 | 04:50 PM
Yarnboy's Avatar
I don't think it was from that..It's tough to tell though..I'd believe it if you did it at the track..But I get a tenth for every 10 degree's..
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
Old Jun 4, 2001 | 06:32 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
See here's the thing. The weather at the track was a little worst for race than the time be for I run the my old best. Its the only thing I did differently.
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
LC2 TECH
Oct 13, 2015 11:53 PM
italiano67
Sep 22, 2015 08:42 AM
84 TA NV
Sep 6, 2015 08:02 PM
