exhaust manifolds get RED HOT!
Old Nov 23, 2004 | 06:17 PM
Jaswir's Avatar
Car: 88 Camaro RS
Engine: 2.8L v6
Transmission: TH 700R
just noticed on the left side of engine that the manifold gets super hot i mean it glows! at night!! and burning my spark plug wires and melting them! plus the car doesnt run good at all its real sluggish at take off and hesitakes alot durning aceleration... like theres a blockage also i have had the manifold gaskets replaced and i think before this it ran like that but no where near as bad as now... any idea what i should do i wanna fix it my self
Old Nov 23, 2004 | 06:27 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
did you check you timing? i think if its advanced to far it can cause this. and maybe a plugged cat but i forget from what i have read here.
jeff
Old Nov 23, 2004 | 07:32 PM
nsimmons's Avatar
seriously retarded timing will do this, the fuel is still burning in the exhaust
Old Nov 23, 2004 | 07:39 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Just one side is doing it? Only one side? If so, you may want to check the wiring on your injectors on that bank. Most likely they are dumping fuel and those cylinders are running rich.
Old Nov 23, 2004 | 09:09 PM
Jaswir's Avatar
Car: 88 Camaro RS
Engine: 2.8L v6
ummm when this happened awhile back i noticed both were glowing red... now seems like left side is alot hotter but the right isnt as hot
Old Nov 24, 2004 | 11:51 PM
82z-28's Avatar
Car: 84 z28 or 94 firebird
Engine: 350 3.4L
Transmission: t-5
my 84 s-10 with a 2.8L did the same thing it was my timing. it burned a hole in my rotor. I also gutted my cat (sounds bad) just in case
Old Nov 25, 2004 | 12:28 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
If it's on both sides, chances are it's the timing. Have you checked f/p?
AussiePr0nCar
Mar 6, 2020 04:04 PM
deracer
Apr 11, 2016 12:04 AM
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
