Aluminum Roller Rockers
Old Nov 25, 2004 | 01:06 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
what will Aluminum Rollers do for a basically stock 305?
thanks, Kyle
Old Nov 25, 2004 | 01:32 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
theres no friction with roller rockers, they make you valvetrain work easier.you probley wont even notice very much difference in power. your better off spending you money on exhaust or somthing
Old Nov 26, 2004 | 12:12 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would look to the Comp Magnum roller tips before a full-trunion alum. rocker, but that's just me. I've seen and heard about many sets failing at 25,000-35,000 miles from fatigue related issues. Simple enough, aluminum does not have the fatigue resistance like that of steel. The Comp Magnums are 8430 or something like that, I believe.
And yes, on a factory cam, you do realize something, albeit not that much, but, perhaps one of the key things is the loss of flexing in the factory rubberized rockers (it's amazing how much they flex when in motion). That makes for a more "consistent" valve train all around; you get the most out of a cam, aftermarket or otherwise.
Old Nov 26, 2004 | 06:13 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
what about with a 1.6 ratio?
Old Nov 26, 2004 | 08:55 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
The performance improvement with a set of roller rockers compared to factory ones feels like when you give your car a tune up.
It's noticably better, but it's not some huge kick in the pants or anything like that.
With a factory cam 1.6s would be a good call.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
