high out put 305 heads on 350
Old Nov 26, 2004 | 02:35 AM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
im lookin at these 305 high output heads there 58cc my stock heads on my 350 are 76 CC and i have a 8.5:1 compression ratio would putting on these heads make my compression TOO high?? plz help
MoroteZ28's Avatar
oh yeh this 350 i have is the 260 hp gm goodwrench one
Old Nov 26, 2004 | 05:37 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: high out put 305 heads on 350
Yes, the compression ratio will be too high, and the engine's volumetric efficiency will drop (how well it breaths.) This isn't a good idea.
Old Nov 26, 2004 | 07:18 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
You would have roughly 10.1 to 1 with the 305 heads. If you run premium fuel and keep the timing conservative you will be fine. Also if you install 1.94 intake valves and port the heads you will not lose any flow and should see a nice gain. I'm not familiar with the cam in that motor. You may have to have the valve guides cut down to handle the lift.
Old Nov 26, 2004 | 08:43 AM
MoroteZ28's Avatar
10.1 would be a good safe compression i would liek it to be i dont want it any higher than that but im unsure heres the heads im lookin at
Old Nov 26, 2004 | 08:44 AM
MoroteZ28's Avatar
heres 2nd pic
Old Nov 26, 2004 | 08:45 AM
MoroteZ28's Avatar
last one i know they would need a cleanin but hey im gettin these at a good price
Old Nov 26, 2004 | 10:23 AM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
sorry- i dont have anything usefull to add. i was just wondering whats a good price for a used set of heads.
Old Nov 26, 2004 | 12:13 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
how much advanced should the timing be?
Old Nov 26, 2004 | 12:50 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I ran around 10 base, but advance it until you hear detonation and back off 2 degrees or so.
Old Nov 26, 2004 | 01:57 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Are you planning on porting these yourself? If so Just go ahead and open up the combustion chambers a little. I had mine opened up a couple cc's while I was having them ported and I run 89 octane without any detonation. I really like mine all I have is the bigger valves and a little bowl work and they work great with my setup. I have an insane amount of low end torque. Also you might want to change your cam while your at it, the cam in that motor is about as weak as you can get.
Old Nov 26, 2004 | 02:10 PM
MoroteZ28's Avatar
well i was plannin on takin them to a shop and gettin them professionally polished n yeah i was lookin at another cam but i think ima put them in later after i get all my bolt ons first wiit this car i just wanna make around 350 hp n still able to daily drive it around cuz its my only car
Old Nov 26, 2004 | 02:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Re: Re: high out put 305 heads on 350
This guy has absolutely no clue what he is talking about. The ports of the 601 and 416 heads are about the biggest of any stock SBC head ever made, only the 461X and a few older heads had a bigger volume.
Your volumetric effeciency will go way with the increase of compression.
If your worried about the compression ratio being too high just grind alittle out of the combustion chambers to increase volume. You might also want to measure your volume to get 9.5:1. I highly doubt that your 350 is 8.5:1, more like 8.0:1 or 8.2:1.
Old Nov 26, 2004 | 11:14 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Look on top of the head, where the valve stems and springs are. There will be an eight number code. Post it here so we can tell you what the heads are good for.
Old Nov 27, 2004 | 02:38 PM
MoroteZ28's Avatar
ok ive decided to cancel the 305 heads im lookin @ some lt1 aluminuim heads now would those fit my 350??
Old Nov 27, 2004 | 02:51 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Short answer no, long answer
Old Nov 28, 2004 | 08:13 AM
MoroteZ28's Avatar
hey the 305 numbers are 7936551391
get back me quick !! i have lil time to buy them
Old Nov 28, 2004 | 08:20 AM
Thunderstruck's Avatar
Old Nov 28, 2004 | 08:41 AM
MoroteZ28's Avatar
ahh good or bad man?
Old Nov 28, 2004 | 09:43 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
No good. You need 081, 601, or 416.
Old Nov 28, 2004 | 10:25 AM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
heads
i have a 355 w/-4 cc dished pistons, and a 75.4 cc chamber head, (487x's) and my comp is 9.4:1 and with a set of 58 cc 305 heads would raise my comp to 11.4:1 heres a link to a compression calculator http://www.csgnetwork.com/compcalc.html if this helps you
Old Nov 28, 2004 | 01:25 PM
MoroteZ28's Avatar
ok thanks guys for ur help just saved me some dough i think ima get these vortecs 64 cc heads that are lookin pretty good
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
