Exhaust size and flow..
Old Nov 26, 2004 | 11:11 AM
devilfish's Avatar
Hi
Im about to build the exhaust for my "new" engine.
My engine should deliver around 400chp -+15hp @ 6000rpm
Exhaust setup i got in mind is this:
I got hooker longtube headers, and the hooker front y-pipe.
The front Hooker y-pipe is dual 3" (from the headers ) going to a strait (singel) 3" tube (no cat).
From that singel 3 inch tuben I got the magnaflow catback to end it all. Dual 2,5"
http://www.magnaflow.com/02product/parts/15658_lg.jpg
Im a bit worried that the center 3 inch pipe is going to kill flow to much. ( Going from dual 3 inch to a singel 3 inch )
As I dont have a good exhaust builder around the corner where I live I would like to keep it simple.
Hope you can guide me.
Old Nov 26, 2004 | 04:38 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
First thing is to do a search in the Exhaust board. This has been covered many times.
To sum it up for you...
A single 3" pipe has more sectional area than two 2-1/4" pipes, and just a hair under two 2-1/2" pipes.
The scavenging effect of running the two head pipes into one (granted it's done smoothly. Not a "T" like the factory) 3" pipe can possibly cause a single 3" to flow better than two 2-1/2" pipes (theoretically).
The problem is the muffler. If you really want to make sure the muffler flows enough, do a search under my name for (nevermind. I did it for you.) That will give you the part numbers of two mufflers that will flow enough to support up to ~400 HP, IIRC.
Click here for the search results.
Old Nov 26, 2004 | 04:43 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Your setup will kill all exhaust velocity and scavenging. If you want duals go for 2.25 or 2.5 max.
Old Nov 26, 2004 | 05:20 PM
devilfish's Avatar
ok. But as I said im going to use magnaflow cat back system, im sure the magnaflows will flow enough? My biggest worry is the singel 3 " pipe.
Old Nov 26, 2004 | 05:24 PM
devilfish's Avatar
I never said i want duals?? And what part on my setup will kill power? Is it the singel 3 inch pipe after the from y-pipe??
Old Nov 26, 2004 | 05:36 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Will kill velocity and scavenging, and your single 3" exhaust will be too small for 400hp.
Old Nov 26, 2004 | 05:38 PM
devilfish's Avatar
ok.. thanks...
Old Nov 27, 2004 | 07:11 AM
AJ_92RS's Avatar
Here we go again.
Will someone please move this to the exhaust board so I don't have to look at it.
This type of thinking is exactly why I don't even go to the exhaust board anymore.
Old Nov 27, 2004 | 07:55 AM
devilfish's Avatar
Here we go again.
please explain to me what you mean. I really need to understand this. Im middle of build my exhaust and someone said that my exhaust ide ( as I printed abow ) will be to small
Old Nov 27, 2004 | 01:53 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Its not that its really too small for 400hp, its that its not optimum.
Old Nov 27, 2004 | 02:31 PM
devilfish's Avatar
i know its not the best, but if it holds me back "just" 5-10 hp i can live with that.
Hotrodboba400
Dec 10, 2019 07:07 PM
90formulaVortec
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
