Clunk from front passenger side when braking
Old Jun 1, 2001 | 09:48 AM
Steve89GTA's Avatar
When I use the brakes a little harder than normal I hear what seams to be a shift or clunk sound that I can feel slightly in the pedal. My buddy in the passenger seat can also feel it. I changed the struts/brakes about 6 months ago and the strut mounts looks fine.
BALL JOINTS
I've never changed these, is there an easy way that I can tell if they're gone?
Engine mounts?...Can I test these some way.
Tranny mount is good and all rubber bushing are lubbed and look fine...
Thanks for your help
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Old Jun 1, 2001 | 09:53 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
check the control arm bushings.
Old Jun 5, 2001 | 03:52 PM
Steve89GTA's Avatar
BTT
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
Street Lethal
Aug 14, 2015 08:25 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
