giant flat spot when floored?
Old Nov 27, 2004 | 12:47 AM
ticket-master's Avatar
Car: 85 t/a
Transmission: stick
hey,
i just bought a 85 t/a with 74k on it, its a 305/5speed, not sure if ho or not, but it pulls pretty good with the exception of a flat spot if taken above about 3/4 throttle? would this be a quadrajet problem, or an ignition problem? it pulls all the way up to 4k then just acts like no throttle is being applied at all. is this some sort of safety thing with the electric carb?
Old Nov 27, 2004 | 03:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like a fuel delivery problem. Replace the fuel filter first. Then check the fuel pressure when this condition exhibits itself. You may have a weak fuel pump as well (fairly common).
Old Nov 27, 2004 | 04:09 PM
sellmanb's Avatar
Car: '86 Berlinetta
on top of five7's thing.... have you done a full tune-up yet?
Old Nov 27, 2004 | 07:08 PM
five7kid's Avatar
True. I usually say it, but dropped the ball this time.
Make sure the ignition is up to snuff before chasing carb/fuel issues.
Old Nov 27, 2004 | 09:20 PM
Car: 85 t/a
Transmission: stick
ok, cool, so this could be cheaper than messin with the carb? i was wondering, because driving it the last couple days, it stutters sometimes coming off the throttle in any gear...
LC2 TECH
Oct 13, 2015 11:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
hartsmike
Oct 2, 2015 07:11 AM
aaron7
Sep 30, 2015 09:15 AM
drumstixer
Sep 29, 2015 03:02 PM
