Camshaft installation
Old Nov 27, 2004 | 05:18 PM
92RSSlowmaro's Avatar
Can someone tell me what bare minimum tools I will need to swap a camshaft out? I've never done it before. I sniffed around the board via search, but couldn't find much useful. Any related links or articles would be much appreciated.
Old Nov 27, 2004 | 05:22 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Hand tools, a timing light is prefered, but if you mark your cap and rotor you can do without.
Old Nov 27, 2004 | 05:25 PM
ede's Avatar
ede
common hand tools, puller for the dampner and a 2-3 jaw puller for the crank gear, if you change it, installer tool for the dampner. i wouldn't want to do it without a handle for the cam and maybe a lifter puller. you'd also need a degree wheel and indicator if you degree the cam.
Old Nov 27, 2004 | 05:44 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Duh, i forgot the most important part the pullers.
Old Nov 27, 2004 | 05:50 PM
Yea, I forgot about pullers, too. Luckily, good pullers can be rented for cheap.
You mentioned something about a lifter puller? Is that to pull the pushrods up when inserting the new camshaft?
Old Nov 27, 2004 | 06:12 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Click my sig.
Old Nov 27, 2004 | 06:27 PM
Cool, just what I needed. Thanks!
Caspar
Jun 19, 2016 11:19 PM
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
