Should I Buy These Valve Springs?
Old Nov 27, 2004 | 12:33 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I'm looking for some springs to work with a street solid roller cam.
The springs that are specified for the cam I have, are Comp #977.
But there are some deals on Ebay for used race springs which are apparently stronger than the Comp #977s specified.
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Buying these used springs would save me $100, if they'd work for me.
Should I do it?
Old Nov 27, 2004 | 12:46 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Heres the 977 spring specs you can match up something close.
Old Nov 27, 2004 | 12:53 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Those springs will have way too much seat pressure, i'd find something else. Look at the installed height 2.0".
Old Nov 27, 2004 | 01:21 PM
Car: '85 IROC
Engine: LB9
Those springs would definitely be overkill, by about 100lb, but from what I've been reading solid rollers can take as much pressure as a spring can dish out.
I'd have to use a longer valve and some offset retainers to get the 2.025" installed height, but I have to get some new valves and retainers anyhow.
Would those springs still be way too stiff?
Old Nov 27, 2004 | 01:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I have a set of Isky 9965's paired up for my SR.
Old Nov 27, 2004 | 03:55 PM
Car: '85 IROC
Engine: LB9
I just looked up the Isky 9965s.
Pretty close to the ones I was looking at.
Stek...
What cam are you using those on?
Rev Kit?
Any other fancy stuff needed to make it work right?
With my combo, I don't expect to be seeing over 6800rpm.
Prolly wouldn't want to use factory rockers with those springs, Right?
Old Nov 27, 2004 | 04:05 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Based on my experience, the 977 springs work well with a Solid Roller cam. Springs are an area that you do not want to skimp. Spend the money for the right springs and you will not regret it.
www.geocities.com/dzperf
Old Nov 27, 2004 | 06:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Stek...
Rev Kit?
I am using an Isky custom grind, specs as follows:
Lift w/ 1.5 ratio: .548"/.557"
Adv. duration: 308/314
.050"Duration : 262/272
Lobe Center: 110
RPM Range: 3200-7500
Valve Lash: .028" Hot / .030" Cold
I do have a rav kit that I plan on using as well.
Maybe just me, but will all that spring pressure, I invested in some strong pushrods.
And no, don't think I would use factory rubberized rockers
I guess for me, the biggest thing is the installed height. Without getting crazy, the tallest valve I found was by Manley and was like .200" taller. That said, those valves took my to my desired installed. But again, I am building this for Gingerman (road course) use and will be revving higher. You could probably get away with a slightly lesser spring.
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
