Different Horsepower Ratings??
Old Jun 5, 2001 | 10:15 AM
Drakar's Avatar
I have searched the NET high and low and I have had conflicting reports everywhere and would like someone with vast knowledge to set me straight I have an 89 GTA 350 with N10 dual cats and I have seen people say that GTA's in 89 have 225hp and 235hp (with dual cat) other sites, say that it is 230hp and 240hp(dual cats) same as Camaro's. I assume it is the same as the Camaro because the drivetrains have been almost identical since 82. Can someone set me straight please.
89 GTA 350 no mods .......... YET!!!
Old Jun 5, 2001 | 10:48 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
225hp, 235hp(dual cat) due to the more restrictive air cleaner assembly. The TPI firebirds were 10hp less than the Camaro from 85-87, and 5hp less from 88-92 because of a revised air intake for the Firebird in 88', but it was still inferior to the Camaro's.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Jun 5, 2001 | 11:25 AM
Drakar's Avatar
Thanks for clearing that up!!!
Would going to the SLP cold air induction kit (single) bring it up to Camaro specs or better??? Has any one used this or had good bad results with it?
Old Jun 5, 2001 | 01:50 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Drakar:
Would going to the SLP cold air induction kit (single) bring it up to Camaro specs or better??? Has any one used this or had good bad results with it?</font>
Not worth it IMO. You would be better off looking for HP elsewhere, like exhaust.
Old Jun 5, 2001 | 08:36 PM
Car: '89 GTA
Engine: ZZ6TPI
Since you have an 89', you already have most of what the SLP kit comes with. All I did was get rid of the stock canister and put a K&N conical filter in it's place. Use some black RTV and a hose clamp. Also, I made a sheet metal wall to block the hot air. That will get you it to the Camaro specs. Also, you can buy just the filter and the fender adapter from SLP for around $90, which would give you the SLP setup since you already have the ducting.
Magnaflow cat-back,
K&N open element,
Old Jun 5, 2001 | 09:52 PM
Guest
Guest
Posts: n/a
I'd check the GTA source page for a sure answer if you want a net answer...
From the 1989 Pontiac sales brochure:
"5.7L V8 High Output with Tuned Port Fuel Injection: 225 hp, 325 lbs-ft torque in Trans Am and GTA; 235 hp and 330 lbs-ft torque in Formula."
Seeing as how the Formulas had the N10 that year...
Old Jun 5, 2001 | 10:37 PM
Drakar's Avatar
Thanks I think I will go with the SLP cold air box only and K&N.
89 GTA 350TPI Bone Stock or as I like to call it All Original,
PurelyPMD
May 5, 2016 04:57 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
dbrochard
Sep 25, 2015 04:56 PM
