Copper head gaskets for 350
Old Dec 2, 2004 | 03:52 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Okay, I've been looking around at various head gaskets and I'd like to be able to buy them from a local parts store. Autozone carries some Felpro composite ones but those are probably very thick.
Then I saw that they had some Felpro .020" thick "dead soft copper shims" to restore the "machined-away" thickness of the block/head. Can these copper "shims" be used by themselves as head gaskets, and are there any negatives to this? The aluminum heads will be decked before installation. I belive the price was about $25/each.
Old Dec 2, 2004 | 04:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'm no sure about those, but i do know that there are several copper head gaskets out there that have been used for decades, so...
FWIW i was going to use some Mildon copper HG's on my 383 project, but i'm not going 383 anymore.
The only thing is that your supposed to coat them with hylomar sealant.
Oh yeah copper head gasket are reusable for upto 6 times.
Old Dec 2, 2004 | 04:53 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Get ahold of some COMETIC head gaskets, any size you need..
very pricey though...
Old Dec 4, 2004 | 11:48 AM
Car: 1997 Corvette
If those are really expensive, I'd just as soon buy a standard head gasket.
The reason I was thinking the copper shim may work is because it says it can be used on either surface, so I figured it should work with both surfaces
Not sure I know what hylomar sealant is. What exactly is that?
Old Dec 4, 2004 | 12:04 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Hylomar--A non-hardening, polyurethane based compound used as gasket maker, gasket dressing and thread sealant. Impervious to gas, oil or any automotive fluid.
Features
* Non hardening and non setting
* Unlimited assembly time
* Vibration resistant
* Allows metal to metal contact
* Resistant to combustion products, water, engine coolant, petroleum, lubricating oils, kerosene and fluorocarbon refrigerants
* Seals surface imperfections
* Withstands rapid variations in temperature
* Flame, dust and moisture proofing properties
Old Dec 5, 2004 | 01:24 AM
Car: 1997 Corvette
Hmmm cool stuff.
So does anyone know if these copper shims can be used by themselves as a head gasket?
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
