need help finding oil leak
Old Jun 6, 2001 | 09:40 PM
mjdoyle's Avatar
OK.. i have an oil leak that i originally thought was the drivers side valve cover gasket.. from underneath the oil appears to be running from the rear of the gasket... well i just pulled the valve cover and the gasket looked clean... could the leak be coming from the oil pressure sender unit or distributor??? how do i find out i cant see a thing back there...
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3" Cat Back, MSD Ignition, K&N, AirFoil
Old Jun 6, 2001 | 10:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It could be the sending unit or the pipe to it, but I doubt it's the distributor. The other possibility is the intake gasket.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
MY87LT
Aug 17, 2015 08:43 AM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
