MSD Ignition - Distributor/Alternator
Old Dec 4, 2004 | 10:04 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
Im looking to upgrade my ignition and aleternator, nothing fancy, just a direct replacement.
Is this Distributer a direct replacement:
MSD Pro-Billet Chevrolet PN 8365
NOTE: The PN 8365 is designed to replace GM HEI Distributors that use a 4-Pin ignition module.
(How do i know if i use a 4-Pin ignition moduel, i have an 84 L69 Quadrajet carbbed z28)
Also what plugs would you use, and would Accel 8mm hi-temp wires work ok, or would u stick with an msd wire?
Also what type of alternator is a direct replacement? Plugin or one wire? Also is putting in the MSD 160 amp (PN 5111) goinhg to be ok? How many amps does a factory alt. run?
Old Dec 4, 2004 | 10:07 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Factory should be 100 amp
Old Dec 4, 2004 | 10:08 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
also what type of bracket and pulley would be used to mount the alternator?
It wouldnt just use a stock belt?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
