Smoke
Old Dec 5, 2004 | 08:49 PM
86'Bowtie's Avatar
Car: Hugger Orange Camaro
Smoke
I've got this problem where smoke or steam is coming from the valve covers and through my valve cover breather.
I know that a pcv valve could be the culprit, but what else am I looking for. I mean blow-by, blown gaskets, what could be the worst case scenario? 'Preciate it!DUECE
Old Dec 5, 2004 | 09:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
PCV bad or clogged vacuum hose, probably nothing bad.
Old Dec 5, 2004 | 10:20 PM
86'Bowtie's Avatar
How could I check for these problems?
When I put my finger over the pcv valve I still get suction.
So...what else am I to look for?
Old Dec 7, 2004 | 08:36 AM
86'Bowtie's Avatar
also would an intake leak cause them to smoke also?:shrug:
Old Dec 7, 2004 | 08:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes an intake leak can cause that; if the leak is across the bottom of one of the exhaust crossover passages.
Worn valve guides will also cause it (probably the most common cause actually), by letting exhaust gas into the crankcase around the exhaust valves. That's sort of the corollary to the startup puff of oil smoke, from the intake side.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
