holds at 3,000 rpm after 85mph?
Old Dec 6, 2004 | 01:27 PM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
ok guys im not sure if this a governer or not but when my speedo reads 85mph (which is actually about 75mph because of my 3:42 gears in the rear) my car holds a 3,000 rpm until it reaches 105mph and then it starts cutting out fuel. it sortof sound and feels like a rev limiter once i reach 105mph.
do i need a chip to override this or what do i do to fix it
Old Dec 6, 2004 | 10:10 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
Your car "probably" has a 'speed limit" or Fuel Cutoff MPH that is not allowing it to run faster.
This was programed into the chip because of the tires the factory used. The tires are/were not rated for a faster speed so the factory limited the speed to "protect" the consumer.
Get yourself soem "Z" rated tiresand have the limit removed from the chip.
BTW, you WEREN"T on a public throughfare going that speed were you?
Old Dec 7, 2004 | 12:06 PM
tc3's Avatar
tc3
Car: 1991 Camaro RS
Engine: 3.1 MPFI V6
will the speed limiter do anything at 85 tho, i would think that maybe that is either something wrong with the torque converter or maybe just the way it works...
pjsparts
Oct 29, 2025 06:39 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89 formula TPI
Sep 7, 2015 10:19 AM
