Fuel pump pressure???
Old Dec 6, 2004 | 04:36 PM
chevyz28r's Avatar
Car: 93 Z34
Engine: 3.4
Transmission: auto
Hello,
I have a 93 Lumina Z34 3.4 auto. Its been a great car!!
I lost the fuel pump a few months back, I changed it , and its been fine for about 2 months. then it started to whine, still ran, so I got them to give me a new one. When I pulled the old one out there was glay like dirt all around the screen (yes it was new), I cleaned the whole tank out. I changed that one, now it pits and sputters........I checked the fuel pressure and it was up to 60 lbs. Thinking the fuel pressure regulator was bad now, I changed that also. still doesn't help ??? When i turn the key on, the pressure goes up to 80 lbs.......when the pump stops......it goes back down to 40. when i try to start it it shoots back up to 70-80 lbs again???? could the pump be the wrong one and pumping to much to over power the regulator???
Old Dec 6, 2004 | 04:56 PM
ljnowell's Avatar
Old Dec 6, 2004 | 05:27 PM
chevyz28r's Avatar
Car: 93 Z34
Engine: 3.4
Transmission: auto
fuel pressure
Or am i over looking something else???
Old Dec 6, 2004 | 06:05 PM
Vader's Avatar
If this were a ThirdGen, I'd say your fuel pressure is excessive. Since it is NOT a ThirdGen, I'd say you need at least 60 PSIG to start the engine, and the regulator may be sticking a bit, but pressure should still be acceptable at 80.
And since it is NOT a ThirdGen, well, you know the rules.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
