Car will not start
Old Dec 8, 2004 | 03:19 PM
Darklord70's Avatar
Car: 1989 IROC-Z
Transmission: Automatic
Car will not start
I have an 89 IROC 350/TPI and she will not start. I have replaced the battery, starter, ignition module, the ignition switch , and the neutral saftey switch. She still will not start......Help
Old Dec 8, 2004 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
What will it do?
What happens when you turn the ignition to run?
What happens when you turn the ignition to start?
Do the interior lights work?
Do the headlights work?
Old Dec 8, 2004 | 06:43 PM
Darklord70's Avatar
Car: 1989 IROC-Z
car will not start
Yes, I get headlights and interior lights. When I try and crank her up nothing happens. The security light comes on for a few seconds then goes off.
Old Dec 8, 2004 | 06:49 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Sounds like your VATS is screwed up. Do a for "vats" to solve the problem.
It's never a good idea to throw parts and money at a car for ant reason. Always test or have parts tested before replacing it saves both time and money.
Old Dec 8, 2004 | 06:58 PM
Darklord70's Avatar
Car: 1989 IROC-Z
Car won't start
What about the lock cylinder? It has to read the key correctly right?
Old Dec 8, 2004 | 07:32 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yes thats the VATS system, the resistor on your key is probably bad.
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
