92 camaro rs need advise
Car: ford truck and my baby girl a 92 rs
i want to build a motor for the drag strip what would be the best to build for a 92 rs and not really costly to main tain a 400 or a 350 4 bolt main also what rearend would you use and transmission right now it is set up for a standard shift i would like to tub it out and put rasing slicks on it please advise soon im looking for the motor now thanks
Transmission: 4L80E/4L80E
Welcome aboard.
You seem to be biting off a pretty big chunk here. Can we assume you will not be driving this on the street when it's where you want it to be?
Drag racing and low maintenance typically don't go together, especially when you're talking about a car that's being tubbed. But, that's especially true if you add a manual transmission to the mix.
I'd suggest you spend some time using the search function, and browsing around the Transmission & Drivetrain, Suspension, and Organized Racing forums. You'll see what people are doing with their cars, and how it's working for them. In general, the bigger the engine for a given performance level, the lower the amount of maintenance that needs to be done. I've talked to a guy from MN the last two years at the Division 5 NHRA finals who has an '82 Camaro, mini-tubbed, 400 CID engine, TH400 transmission, that runs mid-11's. Between 2003 and 2004, he didn't have to fix anything, just did basic oil changes and tune-ups. The car ran very consistent for him.
thank you for youre suggestion's i know i will half to keep up matnace and a long time ago a old man i asked how much it would cost to build a motor for the track and his reply was how fast do you want to go i said very fast he said the faster youy want to go the more it will cost so i under stand that and i will look around and see what others are doing thank you can you suggest any web sites to look at for this
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
84z96L31vortec
Aug 20, 2017 12:16 AM
