Were all IROC L98s 4 bolt mains??
Old Jun 5, 2001 | 06:40 PM
jjstealth2000's Avatar
Im just wondering Because I got mine used and it appears to have had some machine work done to it bye the previous owner.
Old Jun 5, 2001 | 07:19 PM
irocbsa's Avatar
I don't believe that any of the stock IROC motors had 4 bolt mains. They were all 2.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 5, 2001 | 07:34 PM
Guest
Guest
Posts: n/a
Right idea, wrong way around... none of them came with 4 bolt mains.
Old Jun 5, 2001 | 08:31 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Only the Corvette L98 did.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Jun 5, 2001 | 08:34 PM
<font face="Verdana, Arial" size="2">Originally posted by TransamGTA350:
</font>
Do you know what the ID number might be for that Block? For all i know it might be a vette L98. Was there any way to tell besides the ID numbers?
Old Jun 5, 2001 | 09:32 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Even the ID #s won't tell you for sure. I have a 350 block in my garage that I'm building. Using the casting #s that it has I looked it up on www.mortec.com and a few other places. In the description it say 2 or 4 bolt mains. Mine is a 4 bolt, but I only know that because there ain't no oilpan on it.
Well I take that back. There are a select few that were strictly 4 bolt. Look it up after you find the cast #. It should be on the block on either side above the motor mounts. It'll be the last 3 digits, but that's really all you need. GM never used the last three # twice.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old Jun 8, 2001 | 06:07 PM
Blueiroc's Avatar
My 87 L-98 came from the factory with 4 bolt mains...original block even has the VIN stamped on the block...I am positive this is the original block and have been called a liar by so many people....but yes mine came 4-bolt.
-Brian
Old Jun 8, 2001 | 07:33 PM
Guest
Guest
Posts: n/a
I assume you had the pan off?
Old Jun 8, 2001 | 10:06 PM
Blueiroc's Avatar
Have I had the pan off? Yes I have...I took the motor out, had it bored .030 over...forger crank..6.0 manley aluminum rods and forged dome pistons and afr aluminum heads and a shatload of porting up top....now the car is more to my liking...12.96@107mph with only motorwork and a full manual competition shift kit...woohooo!
-Brian
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
mustangman65_79
Aug 11, 2015 03:17 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
