What makes a high-RPM engine?
Old Jun 8, 2001 | 09:57 PM
Xenodrgn's Avatar
The topic says it all, I just am curious to know how you get an engine to safely climb and still make power up around 9-11K...
1985 Camaro SC - 2.8L, auto.
Mods:
Removed air baffles, mandrel bent cat-back pipes (but stock replacment muffler, Dynomax Turbo and Catco converter are on thier way)
Old Jun 8, 2001 | 10:04 PM
ede's Avatar
ede
strong and light weight parts, plus the ability to move large amounts of air
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 8, 2001 | 10:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pretty hard to do with a SBC. Even a 302 only maxed at around 8k. When you look at engines like in an indy car, you need to understand that these engines have a very short stroke and very exotic parts to survive at those rpms.
Easiest way to do it is with an engine with few moving parts. Over head cam engines are better suited for high rpm.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jun 9, 2001 | 12:50 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Several things come into play here.
Main things being
valve train control: Smallblocks were not designed to spin 9K+. Valves are too heavy to remain controled over a long period of time. (I am not talking the 500miles the winston cup motors run at martinsville). I am talking 10K+ miles..
Piston speed: Max speed for a steel rod motor is about 4500 feet per minute. Thats about 8200-8400 rpm with a 3.25 or 3.3 inch stroke.
Airflow: depending on cid, you would need about 400cfm per intake port to feed a motor in the 10K range. Even if it can be done, you cant afford it.
[This message has been edited by jcb999 (edited June 09, 2001).]
Old Jun 9, 2001 | 02:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Spend lots of money.
Old Jun 9, 2001 | 03:24 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Big bore and short stroke promote high RPM's also.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
