I Always thought that the lower the gears, the faster I would go!!
Old Jun 9, 2001 | 12:16 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Like above I thought with no matter what car if you went from 2:73 gears to 4:11 that you would go faster than going to say 3:42. But I have been reading on the message boards by some that you should get gears that match your cam and engine, is this true. I was going to get 3:73, but if the above is true should I go with 3:42.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jun 9, 2001 | 12:51 AM
robbob's Avatar
What do you mean by faster,going on the highway and topping out or do you mean city driving from light to light?
What you have now is good for higher speeds at lower rpms.
If you want better 1/4 miles and 0-60 times go with the 3.42 or 3.73.Most cars that are for the strip only or usually run in the neighbourhood of 4.11 or more.
You could run 4.11 on the street but their not really pratical for a daily driver.
Hope that helps!
Old Jun 9, 2001 | 01:21 AM
Car: 99 Formula
Axle/Gears: 342
I mean by 1/4 mile time, I don't care about top end, how often do I need to go over 100 mph.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Old Jun 9, 2001 | 07:06 AM
ede's Avatar
ede
trap speed is more a function of the HP and will only change as the HP does. et's are a function of how well the car hooks and goes straight. another thing is how much time the car spends going the 1320 feet, less time means less time to make HP or to stay in the power band. on the other hand differant gears may allow a car to make more HP or to stay in the power range longer in each gear and go quicker and faster. the main thing on a drag strip is et the MPH doesn't mean much. ever see a fuel car break or shut down in a run and have a 8 or 9 second et and a MPH of 90?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
mizz0313
Aug 12, 2015 06:45 AM
