Fluctuating Idle and running rough..
Old Dec 9, 2004 | 08:24 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Whats the deal? 350 TBI,,Just got my car back from having the new exhaust and with Hi flow cat installed,...I noticed immediatly the fluctuating idle, and the car shut off on me twice. Now It is not only fluctuating but running rough, like its missing, or something.
When i punch it ...it delays a second , like cough cough,. then winds out and sounds fine running at a high rpm.
DOes this sound like the 02 sensor is going bad? or an arcing wire/electrical?
any ideas?
Old Dec 9, 2004 | 09:39 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
A little more info would be helpful. When you say a new exhaust system, exactly what in the exhaust system was relpaced?
Old Dec 9, 2004 | 09:51 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
A magnaflow cat and a 3 inch spintech cat back, The car was running fine before i took it in to have that installed.
THe technician said,, "it was idling low...so i reset it."
Old Dec 10, 2004 | 01:05 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
a wire came loose and was laying against the header,,,,burned through it and its arcing spark now over to the header.
Im just going to get a whole new set and route them right this time.
What do you guys suggest for plug wires and seperators?
I was looking at some Taylor 10.4 mm's in Summit. probably more than i need but they look cool and have a lifetime warranty.
Old Dec 10, 2004 | 07:36 PM
Morley's Avatar
For seperators, the Moroso seperators are made of a good heavy plastic that seems to hold up to under hood heat very well.
Old Dec 10, 2004 | 09:08 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
Ihad mine run under the headers like they did from the factory had a nice clean look too it
Old Dec 11, 2004 | 06:47 PM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
I gota agree on the Moroso separators. They are in my 82 Camaro and they look really clean, The plastic is super strong and they are super nice and easy to install, plus they make the wires look neat . So id suggest the Moroso Wire Looms. I paid 19 bucks for mine from the local speed shop.
Old Dec 13, 2004 | 08:26 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I bought a cheap set of wires just to get me by now...Im so broke.
I changed all 4 wires on the left side, they were frayed and fried and its amazing the car even ran.
I also bought some cheap seperators, its a temporary setup.,,,but atleast they arent going to get burned up....I also see what i have to deal with when i get a REAL SET of wires.
Im leaning toward the MSD 8.5 mm in red.
Old Dec 13, 2004 | 08:50 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Good choice, I'm running those on my 350HO. I bought the universal kit so i could size the wires myself.
Wish I was paying attention when I purchased them though, I woulda bought the red too, instead of black
Next on the list is a MSD 6AL.
Brandon
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
camaro71633
Sep 1, 2015 10:24 AM
Logan Bryant
Aug 27, 2015 11:52 AM
squiggy2
Aug 9, 2015 09:30 PM
