timing advice
Old Jun 8, 2001 | 11:24 PM
mtg92camarors's Avatar
timing advice
hey
i got a 92 camaro rs, 305 V8.
its got 130K miles.
my friend wants to fix the timing on the car and says it will make it a whole lot faster. will this be good for the engine and does any1 have experience with this? thanks for any advice you can give me.
-92RS
ps. my car sometimes makes loud short vibrations when its first cranks up and is sitting. any advice for this?
Old Jun 9, 2001 | 12:11 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
If u do, u should use some higher octane if u aren't already using it.
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old Jun 9, 2001 | 08:48 AM
Enkil's Avatar
The only way it'll make it "a whole lot faster" is if the timing's about 180 degrees off. Assuming that your timing is close to stock now, it's not going to make a huge difference. Slightly noticable, yes. It can also improve gas mileage if yours is too far retarded. As mentioned above, you'll have to run a higher octane if you advance your timing enough, or you'll run into detonation problems.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
ZMWojnar
Brakes
May 12, 2019 10:43 PM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
