Hooking up F.P Gauge
Old Jun 9, 2001 | 04:28 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
got a procomp 0-100 fuel pressure gauge and need to see how to hook it up. Ive been told to just hook it up to the schraeder (sp?) valve, yet for that to work the little pin inside would need to be pushed down and the braided line from auto meter i got cant do that. how should i hook it up?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, and Ram Air 2 hood
"I'd rather run last in a full out race, than to not have run at all"
Old Jun 9, 2001 | 08:24 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You need to remove that pin inside the valve. Use a valve stem removal tool just like on a bicycle tire.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Jun 10, 2001 | 12:19 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just remember to relieve the pressure off the system before you do any un-screwing. Otherwise you be drinkin' gas baby while your eyes are burning like hell!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
69GTOby
Apr 18, 2016 02:34 PM
gta892000
Sep 16, 2015 12:37 AM
86IROC112
Sep 11, 2015 04:04 PM
