How do I mount an electric cooling fan to an 84 radiator????
Old Jun 9, 2001 | 10:45 PM
CamaroX84's Avatar
I'm in the process of putting in a TPI motor into my 84 Camaro Sport Coupe. The original motor had a belt-driven cooling fan. The TPI motor uses an electric cooling fan which I have. I know how to wire it up, but how should I go about actually mounting the fan? ANY help from anyone would be greatly appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles, 5.0 Carbed LG4, COMPLETELY stock except for a K&N Air Filter, F41 Suspension Package, 700R4 Tranny, 3.08 Open Rear End, New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
Modified 355 TPI
Headers
3" Exhaust
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
Old Jun 10, 2001 | 01:22 AM
Guest
Guest
Posts: n/a
The stock fan has a mounting bracket, which consists of the part that holds the radiator in place at the top, and then at the bottom is a piece that attaches to the lower part of the radiator support. Both are plastic on my car, I am pretty sure they are all like that. You could make your own brackets to mount it, but the factory stuff for a factory fan would probably be easier.
Old Jun 10, 2001 | 06:05 AM
ede's Avatar
ede
there are also zip tie looking things to mount a fan to the radiator. my after market fan is mounted this way.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 10, 2001 | 01:07 PM
Guest
Guest
Posts: n/a
The factory fan wont work that way unless you put spacers between it and the radiator... so with that in mind, and if you want to space it out...
I hate those zip tie things
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
