wont start with MAF plugged in
Old Jun 9, 2001 | 03:41 PM
rezinn's Avatar
I just replaced the MAF, it won't start with the damn thing plugged in. Could it be a relay? Anything besides the maf itself?
Old Jun 9, 2001 | 08:29 PM
rezinn's Avatar
Erg.. I changed the relays, which one is the fuel pump? far right? all three on my firewall look exactly the same... I can't tell the difference. Does it matter? Can't get it to start even with MAF unplugged, Im moving the relays around though.. Help please
Old Jun 9, 2001 | 08:47 PM
rezinn's Avatar
cant hear fuel pump turn on relay is good.. fuse good
Old Jun 10, 2001 | 12:00 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
On my '89 the FP relay is different (least the bracket is?) than the MAF power and MAF burnoff relay's.
You could have a bad relay, but ususally when disconnecting the MAF allows the car to start and run better, the MAF is bad.
But, what may be occuring is the burnoff relay is bad (and you now have it where the FP relay goes) and maybe the MAF hadn't been gettingt he burnoff, which shortened it's life.
Just "supposing"
Old Jun 10, 2001 | 10:39 AM
Vader's Avatar
Rezinn,
The MAF power and burnoff relays should be interchangeable, but not likely the fuel pump relay.
Dependins on which car you have, the relay locations vary somewhat. An '86 TA looks like this:
A MAF with no power applied will not provide any signal to the ECM, so the ECM may presume no air flow. The engine should still at least start briefly, however, since the MAF signal is basically ignored at cranking. The ECM should be providing fuel pulses to start the engine regardless of MAF signal. I'm guessign you have no voltage to teh fuel pump. You can verify this by testing voltage at the ALDL connector, terminal 'G'. This terminal is directly connected to the fuel pump power wire. There should be a 12VDC signal at this line for about two seconds when the ignition is first turned on. There should also be 12VDC whenever the auxilliary oil pressure switch is closed.
If there is no voltage to the pump you should check the fuse and the relay. Lacking that, the ECM controls the FP relay.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 10, 2001 | 01:27 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I'm with Vader on this. Sounds like a fuel problem. The MAF Burnoff and Power relays call for a different part number than the fuel pump relay, however the numbers will cross reference as a substitute so they can all three take the same relay.
Unplugging the MAF should result in using pre-programmed default MAF settings and the car should run if it were a MAF related issue.
specialized
Jun 18, 2022 09:26 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
