Pegged my RPM gauge. How?
Old Dec 13, 2004 | 06:13 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Well, I was having some fun with the new 350 a couple of days ago. . . so I stopped it in the middle of the street back in this industrial complex and just stomped on the gas.
Of course the rear end is all over the place, but all in all, fun none-the-less. . . until I look down and I see the RPM gauge being pegged, then it shifts, and it does this throughout the run. Now I'm pretty sure it's been doing this ever since the engine swap, but I just really haven't been paying attention until now.
Stats for the engine are in the sig, and the tranny is a rebuilt one with a Transgo-shift kit, vette servo, external tranny cooler with a stock converter.
Now we do have to make her idle a little high (fluctuates from 1100 - 1400 RPMs) in order to keep her running (the chip is not dialed in very well), but I'm not sure if the chip has anything to do with the shift points, seeing how it's just a 700R4 and not a 4L60E.
So, should I be concerned with it reving that high? Possible problems or causes of??
Old Dec 13, 2004 | 07:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The stock tachs are horrendously off. I would use a scan tool or get an aftermarket tach to see what you are really running in comparison to your tach. Winaldl will also tell you.
Old Dec 13, 2004 | 07:11 PM
Car: 91 RS
Engine: 350 TBI
C'mon Shifty, we all know about my ineptness when it comes to WinALDL. But luckily, there's someone in my local area with more experience with this stuff, and we're going to meet up and hopefully get some datalogging done.
I think you're right though, because it tells me at 70mph on the freeway that I'm at around 4000 RPM's. . . with 3.23's?? That can't be right can it?
Old Dec 13, 2004 | 08:36 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If you use the calculator on the main page you can determine what RPM you should be running at any speed. However, our speedos are just as far off I have seen in car videos of deweys car and he shifts after the tach is pegged way past 7k. He is really only at 6100.
Old Dec 13, 2004 | 09:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Your RPM gauge/ tachometer is bad, you need a new one. I'd suggest just replacing it with an aftermarket piece.
Old Dec 14, 2004 | 01:11 AM
Morley's Avatar
Where in GA are you?
Your tach is shot, time for replacement.
Old Dec 14, 2004 | 09:42 AM
Car: 91 RS
Engine: 350 TBI
Kennesaw, 20 miles North of Atlanta
Why? you want to help me?
Old Dec 14, 2004 | 09:58 AM
Morley's Avatar
just wondering if you were near me..in Savannah
Old Dec 14, 2004 | 10:04 AM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
"There are patriotic Americans, and then there are democrats."
There are patriotic Americans who are Democrats. The rest are either ignorant or ill informed republicans.
1) There are Republicans who are liberals.
2) There are Democrats who are conservative.
3) The Republicans take your money and give it to their rich associates.
4) The Democrats take your money and give it to those less fortunate than the rich.
Which group are you in? Which ones NEED your money the most?
Not saying your viewpoint is wrong. Just a little something to think about.
Good luck with your engine.
Old Dec 14, 2004 | 10:11 AM
Car: 91 RS
Engine: 350 TBI
Well ok then.
Anyways, is it possible that my RPM gauge might be accurate at lower levels and then become progressively more off as the RPM's increase?
Maybe time for an aftermarket dash?
Old Dec 14, 2004 | 11:43 AM
Morley's Avatar
Yes, mine did just that and then got progressivly worse.
Old Dec 14, 2004 | 11:45 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Well ok then.
Yes your tach is bad.
Old Dec 14, 2004 | 11:48 AM
Car: 91 RS
Engine: 350 TBI
I guess it's just a matter of buying a wire or spring or whatever it is back there huh? Good thing there's a speedo shop about 20 minutes from here that does nothing but fix gauges. How much would be too much to pay for said job?
Old Dec 14, 2004 | 11:58 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
No, throw it in the trash. You can get a whole new set of gauges for pretty cheap, on ebay, the classifieds, the junkyard....
Or just replace the gauge, either with a stock one, or aftermarket. It will cost alot to get it repaired and is just idiotic and republican.
Old Dec 14, 2004 | 12:26 PM
Morley's Avatar
Unfortunately it isn't just a simple mecanical fix, its usually one of the IC chips on the board that goes south.
I've checked online for repair shops, they range from $85-$125 to repair it.
The problem with buying a guage or cluster from E Bay, junkyard etc, is that you don't know if the replacement is going to work or not or if it is what they say it is.
I bought a cluster off E Bay that was supposed to have been out of an IROC. When I removed the tach from it and looked on the back of the face there was a nice little sticker that said " V6"...useless tach there.
Old Dec 14, 2004 | 02:24 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Actually i just remembered i have my old gauge cluster out of a 83 LG4. I screwed up the speedo trying to roll back the odometer for the fun of it and broke it. The tach still works perfectly, let me know if you want the tach or the gauge cluster. I will sell it pretty cheap, make me an offer.
Old Dec 15, 2004 | 09:25 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
UUhhh would you happen to have 2 of those?
Old Dec 15, 2004 | 12:20 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Sorry, i only have one, but he hasn't said anything yet.
Old Dec 15, 2004 | 12:24 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
A fricken men.
My tach is so ridiculously off its sad. It idles occording to the stock tach at 1300. But when I have datamaster hooked up its at 800. 3000 on the tach is 2000 on datamaster. 6500 on the tach is 4700 on datamaster. In fact, I shift at about 5700 rpm's, and it goes past the 7000 on my tach. Stock tachs are useless.
Old Dec 16, 2004 | 04:29 PM
Car: 83 Z28
I'm game if he doesn't get back to you.
Old Dec 16, 2004 | 05:42 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
He still hasn't yet.
Old Dec 16, 2004 | 06:50 PM
Car: 83 Z28
What do you need for it?
Bubbajones_ya
Jul 6, 2024 08:32 PM
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Jk_Under
Sep 8, 2015 08:13 AM
