car idles crappy ????need advice ???????
Old Jun 10, 2001 | 01:24 PM
85witetrannyam's Avatar
at idles it runs very rough and feels like its about to stall.its a 85 TA TPI i have a feeling its the fuel filter because the guy had thrown a new one in and the other syptoms so i looked in my haynes book on how to deprresurize the fuel rail and it said pull the fuel pump fuse and run it till it dies so i went to look for it and there was no fuse where it was supposed to be,there is a car alarm on it and maybe they put some kill switch on it because there is no way it would run without that fuse right? so how else could i depressurize the lines???????/
Old Jun 10, 2001 | 02:47 PM
Enkil's Avatar
I don't think it would be the fuel filter if it runs fine at high rpm's.
Check the IAC and TPS, they cause rough idles.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 10, 2001 | 09:50 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Check what Enkil says as well as the MAF and relays.
First thing is to pull the codes and see if you have trouble codes popping up.
There is a valve on the fuel rails that looks like a tire valve or air conditioner compressor valve. This is the valve that will release fuel pressure.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
bryan623
Aug 10, 2015 11:33 AM
