Water in the Motor
Old Jun 11, 2001 | 03:56 PM
Spyder's Avatar
Water in the Motor
I just got this nice, new virgin 350 ( well not new but sat in some guys barn for a very long time ) well about a year ago some water got into the motor, shotly after they filled with with ATF to prevent rusting.. Well, now I buy it and figure it wouldn't be a bad idea to pull it apart before it goes into my car. Sludge, all I have to say. Its redish sludge. Now my question is, there is no pitting of rust anywhere, just some superfiscal. This sludge crap is all in the cylinders and on the pistons. How do I do a good job of cleaning them? Also should I replace the rings too? I checked all the bearings and they are perfect. Heads also got reworked. Its just sludge that I have to worry about. Any ideas?
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished 305 TPI heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats with two pipes going back, AC delete, SMOG delete, alu drive shaft, 3.73 posi, 170 stat w/ fan switch, MSD Igniton Coil, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
Blow Motor, this July 350 4 bolt, ZZ4 cam and heads and the rest to still be purchased.
Old Jun 11, 2001 | 04:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Let it sit around right-side-up with the pan off, in the sun if possible. Most of the water will drip out and most of the rest will evaporate. Then after just a few miles, like 2 or 300, put a quart of diesel fuel in the oil, run it for a few minutes, and change it.
If there's no rust on the cylinder walls then I would not recommend disturbing the rings, they're OK too.
ICON Motorsports
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
michealleger
Aug 26, 2015 03:29 PM
