How to tell total timing on 89 350 TPI EX coil.
Old Jun 11, 2001 | 02:15 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Right now I've got base at 10* with scanner hooked up it reads between 15-16. On my scanner do I want Knock Sig/ Spark advance? or LV8/ Spark advance? or tell me what other modes to put in my scanner or any other ways. BTW scanner is an OTC
Old Jun 11, 2001 | 05:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's all you'll be able to see via the scanner while you're in park/neutral.
The total advance is in the chip, only way to see how much you're actaully getting, is plug the scanner in and take it for a ride.
The ECM gives advance based on input parameters, and in park/neutral, that's all you need revving the motor.
Sure makes ya crave to be able to just install a vac advance HEI to interface with the ECM, use a fuel trimmer and AFPR for tuning, huh?
But alas, we're in the age of burning eproms for tuning instead of screwdrivers and wrenches
Vintageracer
Jan 10, 2020 05:33 PM
bellez77
Sep 5, 2015 08:39 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
