Detonation problems
Old Jun 11, 2001 | 05:45 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Detonation problems
1987 L98 TPI 159,000 miles.
engine temps - 180 - 200
good oil pressure
happens only when the car is warmed up and under moderate acceleration 3500 RPM +
timing is set to 5* advance
replaced knock sensor - no change
it is very inconsistant. I was assuming it to be due to carbon build from it being a high mileage engine.
However, the car does not see much use lately. Mostly goes out only on Saturday nights. Last week I drove it 2 hours to the track. Ran perfect the whole way there. No knock at all. Made three high 14 second passes with NO knock at all. Drove home 2 hours.. again no problems the car was perfect. I parked it and let is sit until the weekend. Saturday night.. three days later, the problem was there again. It never shows up until after the car is warmed up.. about when the t-stat opens. The engine compartment is very warm, but the gauge reads normal temps, and there are no signs of overheating, and no coolant loss so I believe the gauge to be reading fairly accurately.
Cap, rotor and wires are fairly new.
The car is unning rich because the exhaust manifold bolts keep coming loose and allowing false O2 readings. I am fixing that tomorrow, remove and clean manifolds, new bolts with lock washers. Could this be causing the problem?
I have not done anything with the ESC, but I really don't want to change it unless it needs it.
Any help would be appreciated. I want to know what is causing this before I pull the engine and rebuild so I am not chasing this with a new engine.
Old Jun 11, 2001 | 05:50 PM
mrgto's Avatar
Ever change the timing chain? I bet with that mileage the chain is so streached that it is causing problems.
Old Jun 11, 2001 | 05:52 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
it's the stock chain as far I know
Member of The Connecticut F Body Association
1987 IROC 5.7 - 14.72 @ 92
1988 Formula
1986 Z28
Old Jun 11, 2001 | 05:55 PM
mrgto's Avatar
Ever loose any coolant, even gradually? Those small blocks have a tendency to loose head gaskets. Mine did. It lost coolant slowly and surely but it was another event that made me pull the head and I found out it was a SMALL leak, but there non the less.
Old Jun 11, 2001 | 05:58 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
It's staying right at the "full cold" level.
been there for months.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
