Reasons for high RPM miss...
Old Jun 11, 2001 | 07:33 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
However, I have new cap, rotor and wires all routed correctly. The distributor is also good. Miss is intermittent, i.e. doesn't happen all the time and is worse when the car is cold. Showing no timing is being pulled by the computer on the scanner when it happens. It feels like voltage to the distributor is being cut in half or wires are shorting out on the headers but the wires are perfect. I have a 6AL box on the car. If I unplug the 6AL the problem almost completely goes away, though the car does it worse with the 6AL, like it's magnifying the problem. I really don't think its the box but I want to be sure before I ship it back to MSD.
89RSconvtZZ4TPI MAP system.
Tks guys.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jun 11, 2001 | 04:15 PM
Rob P's Avatar
Engine: ZZ4TPI
Anyone?? Anyone?? Voodoo economics...oh sorry.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Old Jun 11, 2001 | 04:39 PM
Basett_Racing's Avatar
I had this problem recently and it was a little cut in my plug wire. They are Holley Annihilator wires, but they weren't burned, just had a liitle cut, almost as clean as a razor blade cut, and they were arcing off the valve cover. Crank the car at night, and take a look, and you may be able to see. Just a suggestion......
P.S. It was when I swapped over from a HEI with a Hypertech Coil, and Accel module to the Holley Annihilator ignition box when I noticed my problem, so the extra voltage coming from the MSD would amplify this problem.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: first pass- 11.78 @ 112.83, 7.48 @ 91.94, 1.641 60' time
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
[This message has been edited by Basett_Racing (edited June 11, 2001).]
Old Jun 11, 2001 | 06:44 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I had a high rpm miss once, and it was because my intake bolts backed out a little, try and tighten yours.
Check your timing also.
Old Jun 11, 2001 | 08:40 PM
Tom Keliher's Avatar
Rob, I just went through something similar a couple weeks ago. I had a miss under load, at 4000 and above in 3rd gear, and 3000 and above in 4th gear. It was like a rev limiter cutting in.
I got home and looked for the obvious signs, but there were non. Plug wires, MSD connections, all appeared good. I then started the engine, and with it somewhat dark in the garage. I first heard sort of a 'click' sound, and then went to the sound. I then 'saw' the problem. The MSD connectors I had made, were arcing even though they were still connected together.
What happened was the connectors got slightly loose from years of use and vibration. That was enough to make them arc, even though they were fully seated together. I simply pulled them apart, crimped the female spade a bit more, and reconnected them. Problem solved.
Old Jun 11, 2001 | 10:11 PM
idrag2's Avatar
If you have a stock ing. module thats your problem. They start loosing power at 4500. I had the same problem with mine, I replaced the mod. and it was fine.
Hope I helped,
I DRAG 2
eightsixseven
Dec 16, 2024 01:50 PM
Prodigious
Oct 4, 2015 11:20 PM
Dialed_In
Aug 20, 2015 01:45 PM
forstral
Aug 19, 2015 03:20 PM
