Code 43 after engine install....
Old Jun 11, 2001 | 08:18 PM
CamaroX84's Avatar
I just put in my speed density 355 TPI with headers, new cam, adjustible fuel pressure regulator, custom PROM, and a few other minor things. Starts and runs, but I get code 43 (electronic spark control) from the check engine light. I haven't a clue as to where to start to fix it. Also, is this code affecting performance in any way at all? ANY help would be greatly appreciated. Thanks.
[This message has been edited by CamaroX84 (edited June 11, 2001).]
Old Jun 11, 2001 | 10:18 PM
CamaroX84's Avatar
Also, did all years of TPI come with an ESC? This would be a problem if they didn't because I converted an 89 TPI motor to speed density. Thanks.
Old Jun 11, 2001 | 11:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Basically a code 43 means that the ECM isn't getting a signal from the ESC. That could be due to the knock sensor going bad or not having a good ground or connection, the ESC gone bad or not getting a good connection to the ECM, or the ECM is bad. The ECM will either advance the timing regardless of knock (bad for the engine), or it'll retard it, Killing performance.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
