2.8 not starting Helppp
Old Jun 10, 2001 | 10:42 PM
87camarosport's Avatar
I just purchased a 87 2.8 camaro that isn;t starting for me. The car won't start even when fed fuel so I checked the spark. It seems very weak. My first thought was a weak coil but after doing some checking I see it could possibly have some other possible causes. Any advice on what to start with and what to check? It would be greatly appreciated. The car will fire occasionally and try to run but won't start. Thanks in advance. Rick
Old Jun 11, 2001 | 10:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How are you feeding it fuel?
Try unplugging the MAF sensor; the three-wire sensor between the throttle body air hose and the "Y"-shaped air box. Then crank the engine.
You should buy a fuel pressure gauge (for port fuel injection). Mine was $40 from Pep Boys. That way, you'll "rule out" the fuel problem, and can work on the spark problem. Some places might rent you the gauge, too.
Did the car ever start for you? Or did you have it towed to your house? Maybe the gas is just way too old to ignite.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 12, 2001 | 09:57 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
hey man i been thorugh this beforeˇˇ
i bet that it will start ˇˇ
chheck out:
distributor cap
pick up coil (inside distributor(one wire short) and it causes a real headache cause i never think it wasˇˇ)
spark plugs
check for good fuel pressure
check for voltage
good fuel
it may start ˇˇgood luck ˇˇ
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86Base
Aug 8, 2015 01:34 PM
