JetHot Coating an engine block?
Old Jun 12, 2001 | 12:17 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Has anyone done this? Would it flake off? There is a company local to me that does a similar type of coating, and I was wondering if it would work? Would it cause the block to get too hot, since it is designed to keep heat in? It sure would look nice! Thanks guys!
Old Jun 12, 2001 | 12:53 PM
Polecat's Avatar
You could have it powdercoated, but you want the engine to disappate heat, not retain the heat.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Holley 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Jun 12, 2001 | 01:16 PM
Scott_92RS's Avatar
Car: 1992 RS
Powdercoating wouldnt stand up to the heat.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
