Check engine soon light
Old Dec 18, 2004 | 03:52 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
My engine light keep coming on when the car get warmed up, but then it turns off. Then about 5 min later it comes back on again. I think it's the O2 sensor but I'm not certain. I want to be able to check what the engine light is saying. Them Chevy dealer down the road said it would be 85 dollars to check it. (bulls**t) Is there any other way to have it checked?
Old Dec 18, 2004 | 04:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
A paper clip and the ALDL.
Locate the ALDL under the driver side knee bolster. It looks kind of like a plug recepticle. Straighten out a paperclip and jam one end into the upper right hand port (top row, farthest to the right). Jam the other end in the port directly to the left of it. Once the paper clip is in place, turn the key to the on position, without starting it. Watch the CEL. It will blink out the codes. It will start with code 12 (blink -pause- blink, blink). Following that, it will display any trouble codes.
Once you pull the codes, go here:
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Scroll all the way down to the bottom, second to the last Q&A. There is a list of all the trouble codes.
Old Dec 18, 2004 | 10:58 PM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
go to advance auto parts if there is one around you...they do it free and print the codes out for you just tell them is obd1 or just tell them they need to use the aldl cable and its free
Old Dec 19, 2004 | 03:12 PM
oifish's Avatar
Engine: 5.7 TPI L98
Sweet, there is one right down the street. Thanks a ton.
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
