roller cams...I dont get it.
Old Dec 18, 2004 | 04:27 PM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
Ok say i have a block that originally came with regular hydraulic lifters and flat tappet cam. Could i put in a hydraulic roller and hydraulic roller lifters as a direct swap with no machining?
Old Dec 18, 2004 | 04:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes and no.
A factory roller block has 3 tapped bosses in the lifter valley in which a "spider" is bolted down to. This "spider" presses down on 8 dogbone lifter retainers. These lifter retainers hold the tappets square to the cam. Also, up front, there are 2 holes drilled and tapped for the cam retainer plate. This plate prevents roller cam walk. This whole overly-complex system composes a factory roller setup. So if this is the "hydraulic roller" you speak of, then no, it can't be dropped right in as these bosses and the front 2 holes are needed. Also, theres a bit of clearance issues on the sides of the lifter valley, but that's no biggie.
However, there is also a retro-fit roller setup that is far more simple and original in design than this bastardized GM factory roller. This retro-roller just uses simple link bar designs to hold the lifters square, no central spider or dogbones are required. These can drop right into a flat tappet block.
Old Dec 19, 2004 | 07:54 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
True, to do the conversion however, is not inexpensive. You may want to consider going with the stock type cam and just do the roller rockers and a good roller timing chain if you're low- buckin' it.
junkcltr
Aug 2, 2019 11:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
BrianI
Aug 9, 2015 11:52 AM
