thermostat housing bolts to long?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok so i swapped my stock intake manifold for the edelbrock high-flow.
when all was together. i started the motor and coolant sprayed everywhere, i discovered the thermostat housing was not tight, but the bolts were tight, i pulled both bolts and they are the same length, exact same bolts i pulled out of my stock manifold.
is their a reason these bolts dont fit into this aftermarket intake?
it is too late now to go pick up new bolts, though i will in the morning, slightly shorter of coarse
but just curious if thiers a reason for this.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
